Dropping Transmission Pan
ChazMan
So Calif
Do you really have to remove the gear selector cable bracket to drop the trans pan?
I looked up and it looks like the pan could slide forward and clear the bracket, but I am not sure I've never done on this truck. If you've done one, please let me know. Thanks.
Grocery Getter
A guy with a truck.
Phoenix, Az
It will not slide past but you can "gently" move the bracket with a pry bar or long screwdriver enough to clear the pan. I always just drop it and get as much fluid out as possible since it is a PITA and takes some maneuvering to get it out and the fluid will slosh around.....
It can be done fore sure I do it all the time it can just be a little messy......
ChazMan
ChazMan
So Calif
Yes, that's what I was thinking as well. Bending the bracket a bit would be a good idea. For less messy work, I was ablt to suck out the remaining fluid in the pan using a pump once all the bolts are removed and the pan is halfway dropped and slanted forward a bit. Even after all the fluid is sucked out by the pump, I can stuff in some rags/papertowel in there and can almost completely wipe the insdie the pan dry... Removing the two allen bolts that holdking the cable bracket didn't go well for me, especially the front one. Whoever designed this was not thinking...
almightys
I took the bracket off, but to give me more room i dropped the front drive shaft. then I made sure to put a pan in with a drain bolt So I never have to go through that hell again LOL
amaz
Helsinki, Finland
The bracket is held in with 2 torx-socket bolts. Not very hard to remove - 3/8" ratchet with joint and short torx socket it's easy to do.
ChazMan
ChazMan
So Calif
I was never able to remove the either bolt. The rear one was easy to reach but it was so tight and I stripped the bolt head:emotions122:
And I couldn't even place the socket on the the front one, too many other things around it.
almightys
that is why I dropped the front driveshaft. it was hard to get my bear paws up in there
03YukonNH
Manchester, NH
Just did my transmission service today. What a b*tch. I will never do that again. There is a 15 mm bolt to drain the fluid but there was no budging it. I ended up prying the bracket out of the way. Just be ready for a three to fo ur hour plus job
dsump
This is how I did it.
ScottyBoy
Shreveport, La
When I did mine, I just loosened the bolts to move the bracket over enough so the pan would clear. I knew if I completely removed them I would never be able to get them back in without seeing them. Lol
Burgy
