domer94
so I just did a complete job on the rear brakes. first time I did drums. I used a new hardware kit , new adjuster assembly kit, new drums and new shoes. all of it was ac delco professional. I seem to have done it correctly and everything looked ok, but now I notice pulsing when braking at higher speeds. im going to replace front pads as well for good measure , but this condition wasn't there before my rear brake job.
any ideas what I may have to do? I adjusted both sides so there was slight drag on the drums, I made sure I cleaned off the friction surface of the new drums with cleaner. the wheel cylinders were not leaking , but one of the pistion - to - shoe rods was slightly wet where it goes into the rubber seal. pedal is a little mushy , my fluid was low so I think I will have to do a bleed / fluid replacement.
