Dual AGM Battery & Big 3 or 4 Questions.
RVATahoe
Good afternoon family!!!
I recently added some bang in my truck. I have two amps. Pioneer 700+ watts 4way for the highs & Taramp Smart 3k for the subs. Looking for some write ups or some guidance to adding another battery under the hood and doing the big 3 or 4 or whatever. Currently have a yellow top optima on the driver side. Looking to add another yellow top on the passenger side. Do I need a isolator? I will upgrade the alt soon as well.
2006 z71 factory alt currently.
What hooks up to what? which wires go where? :banghead:
Thanks fam.:cheers:
wjburken
Eastern Iowa
Thanks fam.:cheers:
Check out this build thread by @Thatsquishykid717 . He has done what you are looking to do and then some.
https://www.tahoeyukonforum.com/threads/nearly-4-years-later-my-2001-team-dc-audio-build.115721/
Thatsquishykid717
Annoying guy with the loud stereo
All I did when I ran two batteries is had 1/0 audio or 2/0 weld cable either works. Running positive-positive fused between the batteries. Same with grounds. Use the same wire for big 3. Wire from alt + to battery + and ground the alt bracket to the frame along with the battery to frame. That’s your big 3
dmhscorpio
BC, Canada
Make sure both batteries are the same make and model. They also should be approximately the same age.
adamf
