Dual battery setup
SunlitComet
OBS Jedi-Do Good
unknown at this time.
sort of. you do have to remove the rear brace and the mount needs to be moved forward a bit for that. your belt will also become instantly shorter suddenly as well. you can get a longer one but keep this in mine, when i throttle hard and shift 1-2 the mass of the alt will chirp the belt a bit. if i went back to a proper sized belt it would probably be worse. time will tell how it holds up.
saif najd
Did a dual optima yellow top set up, direct connection with 0awg, have a 200 amp alternator, been in for a month now, no problems whatsoever. Took about an hour to set up, I have no reason to isolate.
Some pictures
Wow nice clean engine bay :thumbup:
---------- Post added at 06:39 AM ---------- Previous post was at 06:35 AM ----------
I remember that some old GMC trucks dual battery ready from the factory we should look for that (OEM Syle)
Quintin Colin
I have a 2001 Chevy Tahoe dropped with an LQ4 and a 4l80 I am looking for a good dual battery kit. Does anybody know any good kits?
Tssonebay
