Alberta Tahoe
- Joined
- Apr 25, 2015
- Posts
- 160
- Reaction score
- 33
Besides a host of other issues with this heap, this one popped up today.
A little history. 03 Tahoe 4WD. Previous issues with the ABS motor (open circuit somewhere according to the Tech 2 DTC C0267) That's not an issue in and of itself as I don't mind not having ABS or traction control.
What has come up just recently is a message centre "service brake system". Something relatively new although I'm not certain of the onset is an EBCM malfunction C0251. Haven't been able to locate the cause but while working through possible mechanical issues (although it's most likely electrical given that it's an 03 Tahoe) I applied the e-brake for the 1st time in probably years. Now it's stuck. As a result (or as near as I can tell) this has set off the alarm chime full time while the truck is moving forward.
Any short cuts to freeing this mechanism aside from getting underneath and doing a re and re on the cable assemblies? I've pulled the radio to kill the constant chiming but that's obviously not the answer. Just a way to stay sane while I continue to drive.
I've searched extensively but haven't managed to zero in on an easy remedy.
FWIW, I've pulled the plug on the prop valve as well as the single wire connector on the parking brake pedal but the status remains the same. Probably due to the other issues with the ABS motor and EBCM. Curiously, the ABS issue has been present since I've owned this thing (about 2 years) and have never initiated the service brake system light before. Perhaps this EBCM has started something but I've no way of establishing a timeline.
For all I care, I would eliminate the ABS and traction control altogether provided of course it doesn't complicate matters.
Thanks in advance.
Thanks in advance.
