97yukon
alright guys...i need some help or a suggestion. i installed a fan off of a supercharged thunderbird..motor from the taurus fan but the thunderbird fan is 16" and allows you to put your factory shroud back with no trimming. i hooked it up with low speed cutting on with a thermostat controller and high cutting on with a/c. well it worked for about 250 miles until my truck kept blowing ignition fuses and left me on the side of the road. now i hooked it up with the high speed to the thermostat controller and thats it.
its running off of a dorman 30 amp relay with a 30 amp inline fuse on my ignition wire. everytime the fan cuts on it makes a weird as noise and my battery gauge drops down to about 11 volts and sticks at around 12 till it cuts off. any ideas on how to improve that drag???
