E85
St. Louis
I've never compared the costs/benefit of E85 to 87 octane, only 92/93 octane, as that's what I run if no E85 is available or costs too much.
@swathdiver could answer this question. He's done extensive research and kept meticulous records of it.
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
petethepug
Michael
SoCal
I wonder what the non traditional fuels can do to the engines fuel systems that never intended to run flex fuels.
I don't think it would actually hurt the system as far as the tank and lines are concerned, unless the FF vehicles have different materials in them for the alcohol. I think the bigger concern is if the non-FF pump and injectors can adequately support the additional volume needed. IIRC, it takes something like 25%-30% more volume of E85 to meet the energy level of non-ethanol.
Foggy
KS
E85 Trashes non FF fuel systems. The pumps, lines, injectors are all different.
Even E10 is ******* older vehicles (like pre 2010) ... Those were never
designed to use fake gas -ethanol - in their systems
Not sure about the GMT800s but the 900s and K2s have the same fuel systems whether they were FlexFuel or not. Only difference being programming, injectors and maybe the fuel pump assembly (varies by vehicle).
St. Louis
A lot of hoses and seals made now are compatible with methanol. Years ago, like my mustangs (90s-early 2000s), the fuel lines, seals, and o-rings in the pumps and injectors aren't compatible and will get eaten by the methanol.
To run E85 on my '95, I had to replace any rubber fuel lines and the pump and injectors. The pump and injectors had to be much larger for the additional volume e85 requires.
Topped off today with 12.5 gallons of E85 @ $2.79/gal. $35.
My youngest son is clearing his 'fleet' out of his work storage garage and tomorrow we'll move his '04 WRX on a trailer to his house. Not too far, just within the metro area.
maverick_997
