ebay dual alternator kit?
TnTahoe
TN
make sure you get that amperage at idle number because the alternator has an idle rating and a running rating
you can also change out the alternator and get a bigger one from that seller if ya want, also check the difference betweed the two series they have dominator and something altenure or whatever
sully
I've got the dual 260a kit from DC Power and it is a beast. 520a of current and nearly 400 of that at idle. Cost was not bad, if I remember right it was on sale for around $800 for the bracket and two alts of if you just wanted one and the bracket it would be quite a bit less.
What ever kit you decide to do make sure you use a relay to excite the second alt not just tap into the wire on the original harness or you will throw a code and the charge light on the dash will stay on.
droppedHoe
Lawrenceville,Ga
good info to know brian
mike your running 2700rms, im gonna be running close to 7000rms so yea the stock and a 300... if i had the money (may by july) i'd do a 260 and 300.
linusj
