Electric fan, does this sound right
ktmhans
Connecticut
Hello,
I will probly pick this up if it sounds right to fit and the price is normal.
I have a 2004 5.3 Tahoe
Doner 2005 silverado dual electic fans only. $150 bucks,
I would still have to get the harness from BB i would guesse. Does everyone usually get the pully too?
Rivieraracing
Great price for the fans, make sure you have the bigger radiator though!!
Physh1
If you have the larger 145 amp alt, like I do, than the pulley isn't needed. With the smaller alt the pulley would be recommended.
You should be fine on the radiator size. The e-fans fit the 35" radiator if I'm correct.
Cameron
Rivieraracing
Cameron
Just like Physh1 says, I thought the rad was a 34" that was needed for the '05/'06 fans but could be wrong! I believe that's the measurement between the side tanks on the radiator ( the finned area between)!!
BB harness will work great if you already have a BB tune!
K
ktmhans
Connecticut
Thanks all. I do have the 34" radiator and a bb tune. How might i tell what alternator is on the truck. Its not original and has been replaced.
waxworkz
just look at the back, it should have the amp stamped on it. did you have the pics activated for the fans when you had your tune done?
Rivieraracing
Justin told me that he usually turns on the pins whenever he does a tune, so more than likely he has them turned on!!
K
ktmhans
Connecticut
I bought the auto cal so i would think it shouldnt be a problem if i can figure out how to wire em up.
dph1994
