Electric fan help (for dummies)
ezdaar
Chat Troll
Redneck central, Aka Houston
ok, dude, heres the simplest way to tell if they are correct....
Remove the fan from its bracket. Hold it in hand and have someone Start truck and turn on AC. This is assuming you have the fan relay wired into the AC clutch and not to some thermostatic switch..
While fan is In hand, find out which way its blowing.........
S
Stresst
Its defintely blowing the rite direction BUT wouldnt the blades make a differance? Rather which way the blades are mounted?
Sorry for the hundred questions.:Handshake:
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Stresst, as long as they are blowing towards the engine and turning clockwise front the front looking back the blade orientation is correct. Don't worry about with the efficiency of pusher/puller configuration too much. With what you got there there is more than enough airflow that your heat exchangers can take advantage off.
taylorjm
Saginaw, MI
I think it's about time we start a "Stresst A/C fund". If anyone has been following the threads, you know that he has had some of the worst luck when it comes to getting his a/c working. I think most of us take that nice cold air coming out of our vents for granted. I mean, just the feeling of that nice, 37 degree air, blowing across your face on a 100 degree day....ahhhhh...yet, stresst is still sweating his a$$ off... Therefore, I think we should all pitch in and help him out. If we can all take a jar, and hold it in front of our center vents with the a/c on high, and capture some of that nice cool air, then send it to stresst. Get hot? Just open a jar!
S
Stresst
Very funny!! Better hope I don't come to your house and remove your entire a/c out of your truck! Then we will see who is laughing! LMAO
Gotcha12
