The Fans draw serious power. You have to run relays under the hood, to power the fans. And the hot wire that is being fed to the contacts of those relays has to come directly from the battery, or alternator (preferably with a big fuse in-line). Learnings from having done this conversion on a truck: 1) You need a high output alternator, 2) You likely may need a smaller pulley on your high output alternator, 3) You can't start both fans on high at once, the voltage will dip badly. Low speed first, delay, then high speed.
