Electric Fans
994door
tallahassee,fl
i have the same setup as 961500 but my 2nd battery is there as well so i mounted my relay below the battery that set up looks like the haynes 3647 kit if so it is adjustable temp, can run 2 fans, if you hook up the green wire to the a/c pos it will kick on with the a/c also if you hook the yellow up to the batt 12v constant the fans can keep running until the temp drops. the kit is available at pep boys for $39 bucks
Yukonultimate23
