Electrical issues - watch my voltmeter video
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
What is your amp draw (mV) before and after pulling the RDO AMP fuse?
Those amplifiers do go bad and can cause a draw. I would like to see the data anyway.
And yes, alternators can cause a parasitic drain with the engine off.
Keep in mind that when you are doing amp draw measurements, you need to let the modules in the car go to sleep before you start. Usually on these trucks 5 minutes is plenty.
Also, did not watch your video as it was unavailable.
SLCHOE
Midvale, Utah
As I said before: Video no worky
If this is your FB account, you may have to make the video PUBLIC.
bldn10
bldn10
Memphis
bldn10
bldn10
Memphis
Well, where do I go now? :-/ Took it to AutoZone and removed the alternator so they could bench test it. Passed w/ flying colors.
bldn10
bldn10
Memphis
Seduced and abandoned. :)
Can the alternator be bad and pass the tests?
bldn10
bldn10
Memphis
Still have the problem.
Cameron says my idle is too low but how do you adjust the idle w/ an electronic ignition?
bldn10
bldn10
Memphis
I also have a CEL that comes and goes. Codes are for lean condition. Could it be that when the voltage drops precipitously the fuel pump quits and the resulting mixture triggers the fault code?
NevaLaccin08
