Encoder motor setting it too neutral?
Logan Moore
i removed the transfer case shift motor too replace the encoder ring, and after having done so the transfer case was set too neutral and i attempted too set the shift motor electronically too neutral without being bolted too the transfer case.
the motor moved but is now stuck.
Is there any way i can manually shift the encoder motor too a neutral position?
View attachment 259432 View attachment 259433
By remotely powering it? I think these things have to be calibrated with a Tech-2 or equivalent.
Fless
Super Moderator
Elev 5,280
Why start a new thread on the same subject? You already have another one going on.
