bburgess
- Joined
- Dec 1, 2016
- Posts
- 1
- Reaction score
- 0
Hello, I am new here but have an issue that seems to come and go. I have a 2003 tahoe with the 5.3 in it. (only thing done to truck is cold air, stage 2 trans. engine and drivetrain wise). Randomly while going down the road if i get on it a little bit and the rpms get above 2700+ it starts to bog down and sputter as if it isnt getting power, usually i can come out of the throttle and then go in a little bit easier and it will go away for a little bit. Last night that wasnt the case, went to get on it a little bit and it sputtered a little bit then died, i was able to pull into a parking lot with the speed i had left, and with the key still on a weird noise came from front left side of engine bay, check engine light flashed and the the dash flashed up oil life re set.... anyone had similar issues? thanks in advance for any help.
