07YUKONXL534x4
- Joined
- Oct 9, 2018
- Posts
- 16
- Reaction score
- 36
2007 GMC Yukon XL 5.3 Flex Fuel 4x4 Alum Block 170,000 miles
Current Diagnosis: Timing jumped causing valve train damage to cyl 2 and 4 and possibly more.
I am the fourth owner of this vehicle, having bought it three years ago with 140k miles. Good service history. Pretty clean and very straight. It has always used a little oil between changes, and puffed smoke when changing from 4 cyl to 8 cyl mode. I never deactivated the DOD/AFM. I have never had a major issue with it. It had a few codes when I bought it. I cleaned the throttle body, changed the gas pedal sensor and cleaned the mass air sensor. No problems with codes afterwards. I put a new battery, belts, brakes, tires on it. It ran a little rough at idle so I put AC Delco Iridium plugs and new plug wires on it. Still idled a little rough, not hideous.
Sunday, on our way home from a long trip, cruising down the interstate at 75 mph, not a single warning, suddenly the Yukon went into limp mode and died. SERVICE STABILITRACK light popped up. I got it over to the shoulder and checked the gauges. Info center showed stabilitrack message (I know this could be many, many different things). I tried to re-start it. It would crank, but not start and it didn't sound right. I tried several things on the side of the road including pulling the On-Star fuse, tried to pull negative battery cable to reset the computer, etc. No luck. Nothing obvious I could see either. I jiggled every single sensor connection I could get my hands on. No change.
We were several hours away from home, but we had friends who knew people in the area. We found a good towing service and got the Yukon to a reputable mechanic’s shop. This was a Sunday so the mechanic was not there. I tried one more thing, I bought a 24” long ground cable and grounded from the stud on the firewall to the alternator bracket. No change, turns over, but won’t start. I had to rent a car and leave the Yukon behind so we could get back to work and the kids back to school the following day.
The mechanic checked compression. Cylinder 2 has low compression. He pulled the valve cover and everything appeared to be operating correctly. He thought it may be valve seat. I asked him to pull the head to confirm bad valve seats before I committed to repairs. He called back later and said cylinder 2 and 4 are low compression, push rods are bent and possible collapsed lifters. He said the timing jumped and caused this collision of parts.
Price to replace cam, lifters, push rods timing chain bits, etc... $5,000 roughly out the door price.
Price for salvage engine w/ 113k miles 6 month warranty: $5,300 out the door
Price for a reman Jasper engine w/ DOD Delete 3 yr/100k mile warranty: $6,600 out the door
(The engine itself, my price online, is $3,660, skid charge $15, Install Kit: $464, Prem Serv Plan $255 for total of $4,394 engine only. Labor, supplies and taxes make up remaining $2,206).
Does this sound correct? Anyone else had this issue or similar? Does the pricing seem accurate?
I’m getting the engine swap quoted at a local shop just for comparison sake. May be cheaper for me to have it towed home and have work done here instead. Thanks for any tips, advice….condolences. HAHA!!
