Engine harness plug identification
jeffg
getting close to having the engine in and ready. I have a couple of plugs I can’t remember where they go. Any help identifying these?
SOLVED - This plug goes into a sensor on the AC hardline.
justirv
Could this connector be for the A/C clutch? I'm not sure which ground cable you are referring to.
J
jeffg
I already have the ac clutch plugged in. It’s on the same branch of the harness as the ac clutch.
The ground I am looking is the smaller of the two coming right off the negative battery terminal. I think it goes to the frame somewhere.
justirv
I'll go out and take a look tomorrow.
davidaham1963
if its short, to the fender. most of the time you drop these wires and they tend to drop back via their own memory pretty darn close to where they live.
I have the same problem on a 1998 Tahoe and if you drop the wire plug it's down around the throttle body in that area between the alternator and the cover for the throttle body
Scottydoggs
NJ
if theres nothing with in its reach, its possible its just a extra pig tail for a option you dont have.
Austin prather
