Engine puff when I turn it off (sometimes) - 08 Yukon Denali
plush
When I shut down, my engine puffs, or pops, sometimes. Reminds me when i had my 70 Cutlass ans it had some issues with the carb. What would be causing this? Just a lot of strange stuff going on. Also, when I hit the gas (to the floor) at first it kind of whoomp (reminds me of old old vacuum leak). Guy at Autozone where I was checking my alt said that is normal for my CAI (K&N, AEM, etc). I found this strange.
Any guidance or help.
04ctd
Charleston SC
how much oil is on your K&N?
the IAC has a small passage, and oil or stuff getting in there will make it idle bad and act strange, but never heard of either of your problems.
high mileage vehicles need the IAC passages cleaned anyways, so might try cleaning the throttle body & see what happens
hth?
plush
plush
hth?
Actually, I have the AEM, he just referenced it as a K&N. I have 39k on it, but only 1k on the AEM.
Gzes
the drifting 2dr
Wichita tx
Hi did you take it to a shady mechanicor buy it used? Might be a bad mess with a bootleg redneck quick fix but might be something that could continue and turn out to b something major that will be very bad for a truck that new. Try flushing the carb also and use some fuel injector cleaners might be that they are dirty. Do you have factory warranty? If so take it to them and see what they can undercover and possibly fix.
plush
plush
um, stupid question here, where is the carb? I cleaned the throttle body and bought some injector cleaner. Yes, it has a 3 month 3,000 mile warranty but I don't know what it is and last time I had it in to get something check they ran it an no codes came up.
ChevyGuy
The CAI should have no impact on what you are experiencing, unless it was over oiled when installed and the MAF is now dirty.
plush
plush
Nope, These AEM are not oiled, I'll get some MAF cleaner to see if that helps.
stevek
Dallas, TX
Carbs are only on naturally aspirated motors (not fuel injected like 99.9% of today's cars)
plush
plush
That is what I thought, but the guy said 'flush the carb'.
Also, the whoomp is the throttle body flapper (whatever it is called).
And, something I did not know, when I remove my tube going into the throttle body, the truck dies. Is this normal?
Meg_az19
