Engine 'Stumbles' When When Accelerating
PNW_IT_Guy
My 2010 Yukon SLT 5.3 has a weird issue that I haven't been able to find anything online that's exactly the same. When I'm approaching an on-ramp and I hit the gas, sometimes I can feel the transmission downshift, then the engine revs up and starts to accelerate, but then it just... pauses for a moment. It's just a moment then it gets right back into and goes. Maybe I'm just not searching for the right word. It's not that it generally 'runs rough' but smooths out when accelerating, it's not that it's always rough when accelerating, it doesn't die completely and need to be restarted.
It'***** it, downshift, pause, go. It does seem to have a slightly rough idle, but generally seems to run reasonably well.
Also, no lights on the dash at all. Transmission was drained and filled and oil changed just this past fall. It's a used truck that I bought with 180k a bit more than a year ago. Hopefully I've answered all the basic questions. Thoughts?
Marky Dissod
1st thought:
What did you say? This forum operates under the assumption that words hurt.
2nd thought: Before you fire the parts cannon, consider firing the parts derringer, crank & cam position sensors.
Clean the MAF sensor.
3rd thought: Can you get someone (preferably a tuner) to sit next to you with their laptop hooked up to your OBD2 port,
reading the realtime telemetry as you drive, especially as this peculiar behavior exhibits itself?
Before you drive off, check the throttle position sensor for linear response.
P
PNW_IT_Guy
geez, sorry I guess I missed a space at the worst time. *hit it, not what they thought i said.
Crank and cam sensors aren't too spendy, so I guess I could try that. But shouldn't I get a check engine light if they are bad? I think I have cleaned the MAF sensor but it's been a year so I could give it another go.
I wish I knew a tuner. I do have the Torque app so I'll check to see if it shows throttle position. Pretty sure it does.
Thanks for the input!
John B Good
