Engine temp gauge
malones99
malones99
found it at autozone... they call it a switch! I will check the ohm's in the morning! THANKS FOR ALL YOUR HELP!!!!!!!!!
DallasTahoe
duralast TU230 at auto-zone I think. Vehicle application selection is jamming on me.
I know this is an old post but I was having the same problem, I changed it out and now my check engine light is on, I tried three times to disconnect the battery to clear the codes, each time for about 30 minutes and the sel is still on, is it one of those codes that needs to go through 100 run cycles to clear? Thanks
DallasTahoe
I even plugged in the old one to see if it would change but it didnt
DallasTahoe
Never mind it went away, idk why or how.... Gremlins
Regulator23
