Engine turns over but won't start?
but all those codes shouldn't be there
you could try unplugging the temp sensor maybe and/or the maf connector and see if does anything different
T
Timee
is that the sensor connected to the throttle body?
no the maf is right after the air filter box, the temp sensor is on the engine block drivers side, should look similar to this
T
Timee
i disconnected the maf sensor and the engine hot went away but other codes still there. Do you think the ecm has something to do with this all?
if it wasn't having issues previous to this then it sure sounds like it, I would inspect that ecm harness real good and make sure a pin didn't get pushed out or soemthing
T
Timee
will have to contact the tuner checked all the pins they all look straight none pushed down all same level. Do you think it still could be the fuel pump though?
Time to do a little diagnostics as @Doubeleive suggested. We can guess all day, but without the results of some testing and more information, we're just throwing spaghetti at the wall and seeing what sticks.
T
Timee
Fixed it thank you guys for all the help much appreicated
BKraft
