I have a 2008 Yukon Denali with 165,000 miles on it. The other day I jumped in it and the door locks were going crazy all on their own. Then service stabilitrak came on. Then a check engine light. I scanned and got a P0700 and U0073. I cleared them and it drive home fine. After sitting for a few days I jumped in it again and this time check engine light, ABS light, stabilitrak, gauge cluster going crazy and the truck wouldn’t get out of 1st gear. I then pulled the codes U0100 and P2544. I cleaned the 2 grounds on the firewall by the fuse box, the one on the frame underneath the drivers seat, and the one coming off the battery to the head of the motor. I also cleaned the positive cable going for the max 175 amp fuse, the fuse itself and the two leads leaving the fuse. The truck now intermittently starts and sometimes has no crank no start. I also now cannot communicate with the ECM or TCM and can’t get any codes. When I am able to get the truck started which is completely random, I hear clicking under by the pedals and have no readings for the gas, oil pressure and temp gauges. And still have ABS light, stabilitrak light and check engine light. I have also check every fuse on the truck and they are all good. PLEASE HELP!!!
