Bigburb3500
- Joined
- Jun 7, 2024
- Posts
- 462
- Reaction score
- 771
If you have a Ram, then you know I would KILL to have the towing data screen they have. Way more info and super helpful.Also, the more i look at the comparison photos, the more i'm pretty sure this can work. Keep in mind, even after transferring the internals around, the IC will need to get sent off the WAMS to get programmed. And depending on the donor your got, it may not work. I spoke to WAMS prior to ordering If you are like me, and are looking to also add carplay at the same time, ONLY a 2016 IC will work for you. That has to do with the programming on the tech savvy side of things which i'll be relying on WAMS for so that everything works after the fact. But assuming my half of the plan works, this will be a worthwhile project for me to have one of the only properly done Esky ICs on the planet. Kinda like how my 18 ram is one of the only handful in existence to have factory blind spot monitoring. Sometimes manufacturers just don't offer everything you want, so you have to rifle through their parts bins to get it.
My truck has CarPlay, so it would need ONLY a 2016 IC?
