Escalade side mirrors on a Tahoe LTZ!
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Resurrecting an older thread here...Looking to swap my mirrors for the larger Escalade mirrors. I have a 2018 Yukon Denali. Who would be best to contact to confirm the Cadillac part numbers I would need? I believe they are 84664802 and 84664803. It looks like I would also need the caps/covers 23463315 and 23463316 and have them painted. Is there a resource where I can confirm the correct part numbers? Thank you!
Those GM #'s are
DL3- T/Sig, Elec, Heated, Power Folding
Covers are paint to match.
They are from an Escalade 18-20
RST Dana
OH
There are a couple of series if I remember correct. The latest has the camera as well. Unless you are tackling the 360 camera challange, they will not be used. Once painted, 15 minutes per side to swap out. Careful removing the covers, they can be tricky. Had to look long for a video on how to remove the covers.
07 Denali
Thanks Dcmaynor. From what I can tell there are two series for the 2018 model...like you said, one with the camera and one without. However the one without the camera also does not have the blind spot monitoring. My intent is to get the mirrors with the camera so that I have the full functionality of the Denali mirrors (blind spot, blinker, power fold, heat) and just not use the camera while still keeping the system plug and play. @Dcmaynor am I on the right path here? I will search for that video on the cover removal. Thanks for the heads up. Where are folks getting their covers painted?
RST Dana
OH
yes. I needed blind spot, heated, turn and power. You will be glad you did this..
RLC2020
I'm about to do this mod as well. I just ordered a set off ebay that are Passion Red from a 2018 Escalade. I hope they match my Crystal Red Tintcoat! I'll post pictures when I do the swap next week. I tow a boat and a utility trailer every week and these tiny mirrors are a joke!
07 Denali
Definitely a worthwhile mod. Just a quick FYI on the install...if your mirrors have all the bells a whistles, I believe the puddle lamp and blinker are the things that will work when you plug in the mirror. The power fold and power mirror adjust will not work until you plug the door panel into the harness. When I installed the mirror I had a bit of a WTF moment when I plugged in the mirror and not all of the features worked. Rest assured when you reconnect the door panel she'll come to life!
RLC2020
Got them installed last night. The color is a damn near perfect match. Everything works except the blind spot, I don't think these mirrors have that feature even though the listing said it did. I can live without that thought. They look great and are way bigger than stock.260196235_487101295883499_7202058451254106434_n.jpg
256675193_364459438813687_2282021464681078003_n.jpg259444195_380332507217852_7572699153243455327_n.jpg
rsetareh
