esky 3rd brake light
adventurenali92
Big Bear Lake, ca
@felixgun , that's clean! I like it! I dont get why they had to be so difficult and make two setups either. Its pointless. But I wanted the setup like mine So that everything hardware wise stays the same because I'm **** like that haha.
Gtir007
can you tell me the difference because i have 2 escalade panels and was told one is from the 06- dont want to sell you the wrong part
adventurenali92
Big Bear Lake, ca
@gtir, the base and light are both the same. But the base on the one I need will not be bolted directly to the glass hatch that can't be separated. It'll have screws going through that can be unscrewed and separated from the hatch.
felixgun
Lafayette, LA
I have one for the newer one and have an older glass with the rubber trim around the perimeter of the glass. Even though mines a 2005. It's definitely killing me inside but it looks good and the 3m tape I used is the same on door mouldings so it's not going anywhere.
adventurenali92
Big Bear Lake, ca
@gtir, just checking, you Are selling me,this taillight and the base assembly that mounts,to the hatch right? Not just the light lens itself? And the esky assembly? Not the black non painted yuko/suburban trim piece? The two pieces you showed me a pic Of one is the esky assembly and the other is the yukon assembly and I want the esky assembly Not the yukon piece.
michaelkellett
