So I responded to James' thread (
@swathdiver) on his measuring the real ethanol content, versus his calculated content on his trucks. I really appreciate the effort James in getting that measurement. It confirms what others have experienced that many trucks can figure out the Ethanol content quite accurately.
As I posted on one of my responses to that thread, in recent fill-ups, according to my shop manual, I am squeaking under the wire of "normal" at 15% different in real versus calculated (real 6% vs 19% calculated), as long as the truck is running fine otherwise (which it is).
I had one outstanding item I was going to try and test for this thread, which was fuel pressure. As it turns out, literally while I was typing my response to James' thread, the Amazon guy delivered my Actron fuel pressure gauge. I was surprised it was a pretty nice looking piece, great instructions, etc. Amazing when I consider the $25 price tag.
I had a chance to run the same test I ran with the Napa AP loaner gauge, using the shop manual procedure Key on, Engine off and came in at 53 psi, a couple psi lower than the Napa gauge, but close enough for government work. So according to my shop manual, my FP is fine. I then started it up and it too registered exactly 60 psi idling, at 2000 rpm and 4000 rpm, so exactly the same result as the loaner gauge.
I know that everyone who has a model year that has a FPCM, can see their commanded vs running pressure and report 43.5 psi as nominal at idle, as I have found out my 2007 doesn't have a FPCM, so not only can I not see running FP on my Tech 2, it appears the FP management is exactly the same as 2005 and 2006 Tahoes and Yukons, with the pressure regulator in the FP assembly (versus on the drivers side of the engine and using intake vacuum as a reference in pre-2005's).
I have seen a few other YouTube videos of people doing fuel pressure debug on a 2007 Tahoe/Yukon and when things are right, they all report the Key On, Engine off pressure I see (and the shop manual calls out) and running pressures of 60 PSI, so my basic assumption is again, my fuel pump is fine.
The only thing left I have that the shop manual calls out, and only if my calculated Ethanol percentage is greater than 15% above my actual percentage, is to drop the tank and clean my whole fuel system.
That is a lot of work for something that is not affecting the running of my truck other than rich cold starts and those only when I don't reset the Ethanol content to 3% with my Tech 2 after fill up. So my plan right now is to just keep using E10, resetting the Ethanol content to 3% with my Tech 2 after fill ups and just try and love the old gal with all her imperfections.
A beaten man.
