Exhaust for a XL
calima51
Hi everyone,
I was interested in buying a corsa exhaust for my 2011 Yukon XL, but I have been reconsidering it. Because the car is so big, I doubt that I would be really getting that much of a horsepower boost. So that means I would be paying for only the sound of the corsa.
Does anyone have any suggestions/advice on just adding a muffler instead of the whole system?
I was thinking of a borla. Thanks for the help.
ScottyBoy
Shreveport, La
If you want more HP from an exhaust system, you will end up having to upgrade the entire system from the headers to the exhaust tip. Long tube headers and true duals will make a huge difference compared to a cat back system. If you do replace just the muffler or from the muffler on back, it will pretty much be only a better sound.
Big Buttons
The SS Burb
South Texas
Do it out the side before the rear tire like mine lol. I noticed a pretty good power gain.
Colorado Hoe II
Replace the factory exhaust manifold with ARH 1 3/4" long tube headers and Y pipe. Use your factory muffler system.
Administrator
You need to evaluate what your end goal is with your exhaust. Are you wanting more HP or more sound? To be honest, unless you do more stuff than just an exhaust your actual HP gains from an exhaust system on a stock motor are neglible at best. If I was you, I'd decide what sound you want by searching sound clips and go with that muffler or exhaust system. Then to get actual noticeable HP increases get a Black Bear tune and you will be good to go :waytogo: just my 2 cents :shrug:
THE YETI
Director of Operations
South FL
Hi everyone,
So you are saying you'll get more of a horsepower boost from Borla? Or am I reading it wrong?
Are you wanting a quality cat-back exhaust or are you looking for just a sound change?
C
calima51
No, I was saying that if I was just going for sound, I would just get a muffler. I am not too familiar with engine modifications and figured that there is not too much I can do to really feel an increase in power in the XL.
Ideally, I would like to see an increase, but will I feel it that much with a cat back exhaust? I don't know how much I will be able to spend on upgrades such as a big bear tune, headers, intake, etc. to make the truck have some real power.
Your feedback is greatly appreciated.
Administrator
With a good cat back you will feel a notice in overall throttle response but that's about it. I would say that the best out there is probably a Corsa system but it is also a pricey item.
C
calima51
I do want both sound and hp gains, but I guess my question is how much of an increase will the corsa give me? The $1000 that is the reason for my hesitation. If it is only going to give me a minimum increase, then I would just go for sound.
Also, how much is a black bear tune?
---------- Post added at 08:57 PM ---------- Previous post was at 08:53 PM ----------
OK. With that said, what muffler would you recommend? I really like the Corsa sound, especially the "no drone". I have three kids and I don't want it too loud. I have been looking at sound clips on youtube, for boral, magnaflow, and corsa. I really liked the corsa touring, even though it was just a hint above stock. Any recommendations?
Thanks in advance.
Administrator
A black bear tune is about $500 or so but you get a significant performance increase from your vehicle and the majority of people notice a significant increase in MPG at the same time. You definitely get more 'bang for the buck' with that route. Many folks on here go the route of performance cold air intake ($200), mild exhaust upgrade ($300) and then the black bear tune and notice these significant gains with the overall package with the tune being the key to the 'package'. (dollar amounts are approximations and vary with brand and set up)
---------- Post added at 11:06 PM ---------- Previous post was at 10:59 PM ----------
Thanks in advance.
It mostly depends on your budget. Corsa is probably the best (or at least among the best) on the market but it also is $$$$. With regards to the drone issue many people like magnaflow (namely the larger muffler that is 22" long). I've also heard very good things about the MBRP system (sold on stylintrucks.com). In the past, i've always used flowmaster but they produce quite a bit of drone so when I do the Burb I will go either magnaflow or the mbrp system. You should PM Felixgun. He's got a nice setup with his magnaflow with volant tips and he says it produces no drone. He may have a part # for the muffler as well.
Chevy_Boy1990
