fact bose sub
a4edwin
ny
cant believe they call that a sub. by any chance would you know where the amp or the fuse for the amp is located?
kses123
kses123
Raleigh, NC
The amp is located under the storage bin in the console. You can see the connector for it if you pull the cup-holder insert out.
a4edwin
ny
do the door speakers and sub run off one amp or do they have separate amps. and is there a fuse mounted on the amp or would it be in either fuse panel?
kses123
kses123
Raleigh, NC
All of the speakers are powered by the amp in the console. No, there is not a fuse mounted on the amp. I think there is a radio fuse in the fusebox, not sure about one for the amp though.
miguel olea
radio amp fuse uner hood fuse panel. it is a 30 amp fuse. if it was bad you wuld get no sound. Max bass and treb then place a hand on the lower right side of the console edge. you should feel the air move out of the ported sub.
Mr. 960
mohammadamlih
