bcbickers
Greetings All,
My new-to-me 2012 Suburban Z-71 started idling rough and missing this past weekend. With 151k on the clock and the last tune-up done at 75k, I figured it was time for a tune up and swapped in new AC Delco plugs and wires. The hiccup/miss actually got a bit worse and eventually threw a P0306. I thought maybe a bad wire, so I swapped the plug wires between #4 and #6, reset the codes, and drove around. No new codes after 50 or so miles and a 15 minute idle session in the driveway, but now I hear what I think is a lifter tick. It seems to run fine and make no noise or stumble when cold or at speed (oil pressure above 40 psi) but shudders/misses at lower speeds. Do I have a failed or failing lifter? See video.
