Feels sluggish but no proof
haks310
Got LEDs?
SoCal
Timing light is a no go for a 99. 96+ Vortrcs will need a scanner to adjust the timing. I doubt that is your problem though, you would would of had stumbling if the timing was off.
How's your catalytic converter and muffler doing?
vincent m
I'm new to this I have a 98 Yukon it ran sluggish had it check by a macanic at a diler ship I had a burned engine. After I spend close to a grand to find out what was wrong with.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
:welcome:
---------- Post added at 02:33 PM ---------- Previous post was at 02:31 PM ----------
forget the timing issue unless you have a p1345code.
Can you get access to a scanner to see real time activity of O2 sensors?
king_yukon
CANADA
Im curious to an answer for this issue, I have the samething by the sounds of it. I noticed it before I did any of the following.
plugs, wires, cap, rotor, spider injectors, cats, custom exhaust, fuel filter, water pump and coolant flush.
I can feel a light almost stumble in the engine while at idle, driving I can hear what seems to be like a stumble in the exhaust, and if i'm just cruising it almost feels like it's held back sometimes, then goes back to normal but if I get on the throttle then it runs fine.
Meg_az19
