Felix's White on Tan Denali
crazycrew
Vacherie, LA
Felix's Black on Black Esky and Black on Tan Avalanche
Damn. Them suckers are just as bright as the hids
felixgun
felixgun
Lafayette, LA
Yea they're definitely bright enough especially just for looks. The HIDs in the fogs never did much for me anyways.
THE YETI
Director of Operations
South FL
Is the ground loop isolator necessary? Never had those before on any of my stereos. Just wondering..
LEDs look good! :)
felixgun
felixgun
Lafayette, LA
Thanks! Last time I had the system in my 08 Tahoe I had some noise so I heard the ground loop isolators help. I dunno I guess we will see :)
THE YETI
South FL
Hmm.. Usually that's indicative of a few other things. You shouldn't really need em. :Handshake:
blkonblk
NYC
Those Cree lights look great
Regency
Usually that noise you hear indicates a bad ground is what I heard.
felixgun
felixgun
Lafayette, LA
Well in that case I will not install it at first and see if there is any noise at all.
---------- Post added at 09:34 AM ---------- Previous post was at 09:34 AM ----------
Thanks I like em way more then the smd led's.
THE YETI
South FL
Ground wire should be the same size as the power wire. No longer than 3' long. Shorter the better.
Keep power wire and RCAs ran down opposite sides of the vehicle, if possible.
And definetly definetly definetly use a high grade RCA cable. That cheap stuff carries nothing but interference.
felixgun
felixgun
Lafayette, LA
Yep got 4 gauge for both power and ground. It came with RCA's in the amp kit. Not sure how good they are.
tdeaton3
