Fender Height 2017 GMC Yukon XL
jwebhale
Can someone tell me what is the stock height for the fenders on a 2017 Yukon XL Denali w/22" wheel? Mine are 34.5" front and 37.75" in the rear. Is there an easy way to reduce the rear height?
slupie
Bartlett, IL
let the air out, lol
otherwise short answer, no "easy" method
takes money is all
the "easiest" thing to do is level up the front
Biscuit mobile
How high is the rear if the compressor was off and the shocks at 0 psi? Can the rear sensors be adjusted lower to make the rear set lower?
I've only done this on semi truck suspension, nothing that was computer controlled.
no there was a time when the gmt900 Escalades first came out that the rear height could be adjusted but gm sorely found out it caused premature wear to the suspension parts so they deleted the option. and the t2''s self adjust k2's got nada
jonestheclem
