First time rebuilding a 8.6
Tatejohnson1122
Hi y’all this is my first time rebuilding my 8.6 in my 2003 Tahoe 5.3. I’ve re-geared to a 4.11 and am setting my patterns. I’ve got my backlash at 9 thow and this is my first pattern. Is this acceptable or what changes should be made.
T
Tatejohnson1122
Here’s some better photos, did another test, everything the same as first test.
T
Tatejohnson1122
T
Tatejohnson1122
Did what ya said, I added a 0.07 shim on the left side and my backlash is at 0.07 now. Here’s some photos, does the pinion depth look ok?
Maybe a tad high in the left photo? Where's the experts? @Matthew Jeschke @Dan Acosta @Erickk120 @Scottydoggs @yukon702
T
Tatejohnson1122
Sorry for annoying y’all, but here’s my final set up. I had to add a shim to the pinion and add my crush sleeve eliminator. And change out my setup bearing for my finals and here’s what I got at the end. What do y’all think?
T
Tatejohnson1122
Erickk120
Are those 2 cut gears or 5 cut? if two cut drop the lash lower, or they will whine a little on coast 3-6. if 5 cut 7 would be perfect middle of the road. Also If you could run the compound thinner it would give you a better idea of the true pattern, doesn't look bad though maybe a tad deep, but not terrible what pinion shim thickness are you running?
Forgot to add your first set of pics, it looks shallow
T
Tatejohnson1122
I'm running 0.034 worth of pinion shims, stock was .030
the most recent 3 photos are my last run are you referring to those?
mechanic0
