Fishtailing
SunlitComet
OBS Jedi-Do Good
unknown at this time.
I would check your rear suspension bushings paying close attention to your panhard bar.
Seriously?:chair:
---------- Post added at 07:32 PM ---------- Previous post was at 07:29 PM ----------
take a look at the toe in on the front alignment. you don't mention if 2wd or 4wd. make sure the toe doesn't change significantly with suspension compressed. Could have something bent in steering linkage.
The mention of the np246 t-case in his signature did not offer you a clue that it is a 4wd?
noJeepshere
noJeepshere
Bountyfull, Utahrd
If the weight of the vehicle is supported by the lower control arm, should the balljoints exhibit any play?
cent frum a smaert fone
SunlitComet
OBS Jedi-Do Good
Actually the lower just keeps things togetherfor the most part, it is the upper arm and knuckle at the end that is bearing the grunt. They both wear tho. Iirc the wheel has to be off the ground to be prayed with a bar at the joint to see it. Might not be correct tho. I forgot lately.
noJeepshere
noJeepshere
Bountyfull, Utahrd
I had the jack under the control arm lifting that corner, and those balljoints moved, a lot.
God
I fishtail over big bumps too when I'm driving 40+ in a straight line. I feel the rear of the truck shift to the right. It's kinda scary. Curious to know what causes this as well
ihadtheories
