04SS99Denali
Im lost. The truck runs great under normal throttle, Idles smooth not misfiring or anything. Even at around 70% throttle up till 4000 it runs great. When I put it under heavy load (going up a steep hill) or WOT condition it will lose all power and start to shudder as if its misfiring. I pulled the cap rotor, cleaned them again they were replaced 3 years ago (only 5k miles ago). New plugs, new wires also done 5k miles ago. Right now there are no pending codes. Also has a new fuel pump, did this before and still does it after.
Little history, replaced the intake gaskets 3 years ago so pulled the distributor. I lined it up back then and checked again today, put cylinder 1 to TDC and the arrow on the cap is pointing toward the #1. So I do not think its a timing problem.
It did not do this before everything was replaced. Which is why Im confused because nothing seems to be put back wrong.
Any suggestions would be very helpful lol
