Flat tire
zach2011
Platinum Member
That does suck. Where do you unlock the spare tire at? Is it on the rear bumper cover?
Denali132
Banned
yes, when you pop off your hitch cover you will see a little square plastic piece. pop that off and you will see a key hole. They replaced mine last week all I did was hit the OnStar button and somone was out less than an hour.
C
CincinnatiZ
Cincinnati and Miami
Yeah pull the hitch cover (mine got stolen) then there is a square cap off to the right of the hitch. Pry that open with u r finger nail from the bottom. Then use your key to open the lock. After that stick the pole with the SQUARE end in - not the one with the hook for the jack.
Thank God I havent got the lowering kit put on yet or i would have been playing musical tires on the side of I-75.
One more flat tire and Im going to put the stock 22's back on forever.
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
And I just got another one! It happened about 20 minutes ago PLUS I bent the rim AND cracked it! Dont buy U2 rims there JUNK!
My bad luck is unreal. Its killing me. Im about to run this mother fu*$*er into a ditch.
That sucks CincinnatiZ!
Just curious... What size/brand of tire are you running and at what PSI??
dylanrog24
