Flex fuel or gas?
Wylie_Tahoe
Have you confirmed a VIN match on at least 2 other locations on the truck? Like dash and door match and dash and frame match, etc?
So, if that pump has worked previously, I should be okay with the same as a replacement, right?
That leaves me with my original question. Is there a way to tell, by looking at the engine, if it’s flex or gas? Because I think it has been changed. It’s in too good of shape to be original, I’m thinking.
The engines themselves are all the same and I'm pretty sure the only difference between FF and non-FF are the injectors. I don't think the manifold nor the fuel rails are any different since using FF injectors on a non-FF engine for performance purposes (nitrous, boost, big cam, etc.) is a common swap. The injectors do look different. Their electrical connectors are different as well.
FF injector:
Gasoline-only injector:
mattbta
Frisco, TX
What year? Does it have an inline fuel filter, underneath the driver door area? At some point in the vintage, only the Flex Fuel motors got serviceable fuel filters.
Wylie_Tahoe
Based on the VIN the OP posted, its an 03. My 03 F/F has an inline fuel filter canister
Fless
Super Moderator
Elev 5,280
The OE fuel filter will most likely still be there even if the engine was replaced with a non-Flex engine. Doesn't really tell the story. The fuel injectors will.
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
Some here will not agree but I always install a new fuel pump relay when I do an electric pump replacement. It all stems from a story from when I was running shops years ago.
BKraft
