Fog Lights?
Juanillo2023HC
Have been considering a pair of those.
Where are you planning to mount them and will you be using double sided tape or screw/bolt to attach?
In terms of wiring, if white wire is power to switch to signal relay to turn on lights then we need to know if you want a switched power source or power all the time. If switched power source do you want them only on with headlights, running lights or ?
Thank you 66 Galaxie,
I plan to mount them with some L brackets on the plastic piece under grill, I’ll take picks of the install. Plan on mounting tomorrow.
I want to switch them on with headlights.
Here she is when it came in.
Juanillo2023HC
Well installed ‘‘em today, let me know hat y’all think..5E4C2635-06BD-4FC5-8519-4EB7495EFBEB.jpeg
Juanillo2023HC
Juanillo2023HC
66 Galaxie
Great job!
Which wire did you tap so they would go on with headlights?
Details of how you did switch install??
66 Galaxie
Interesting, on my ‘22 High Country (6.2) that lower panel is not open like yours where you mounted the grill. Does your truck have max tow package or Diesel??
Juanillo2023HC
Tapped ito the fuse marked headlights,
Switch was a simple hole , trick was pulling that panel. There’s room tho. I dint take pics.
It’s a diesel, yep on towing package. Never noticed it on my 22 6.2 I traded in tho. Figure it should be the same.
Mounted the Banks gauge today.
GoNoGo
Elberton, GA
I think the diesel wants more airflow so bumper is vented below the grill, makes for a sure enough nice fog light bracket location :thumbsup: Any false-positive triggers (from the new fogs) from your front parking sensors ?
66 Galaxie
Thx!
Diesel needs airflow for the inter cooler so it makes sense.
