Fog retro question
kses123
kses123
Raleigh, NC
Looks good Scott. How about you just make another set for me?! Did you see the guy in HIDP who is doing the same thing you are with his Bonneville (they have the same fog lights.)
DenaliAK
DenaliAK
Colder than you
Alaska
Send me the parts and I'd be happy to do it, but seriously this is so simple it'd be a waste of time. If you went with things like they are in that last pic, it'd probably literally take about 10 minutes to do both lights. It's that simple.
Compared output last night to the Blazers. Both are pretty good for their size. The Blazer was a little cleaner, but not hugely, and they are known for failure with 55w HID's, which I plan on using. We tested with 35w. My buddy did get some comparison pics, but he hasn't posted them yet. I'll post over here when he does. He let me have a couple of shrouds he had laying around, so I'm going to try to fit those in the housing with the projector. Should look pretty sharp if I can get them in, but they are going to need significant trimming.
---------- Post added at 02:15 PM ---------- Previous post was at 02:01 PM ----------
Keith, can you link me to the Bonneville thing on HIDP? I can't seem to find it....
rippinitup
NY.
im planning to retro the p1s into my oem yukon fogs. i dont know how well it will turn out but i will give it a try lol. will the chrome reflector mess up the light output of the projector?
scott, post up pics when its all done i would like to see how the 3k output looks. thanks!
DenaliAK
DenaliAK
Colder than you
Alaska
Scott, i found that spacing and correct rotation of the HID bulbs helped alot in mine..
Yeah, one thing we noticed pretty immediately with the P1's is that there was a significant shadow from the return wire of the HID capsule. I'm going to have to orient the bulb so that's not showing up in the foreground lighting. Also noticed that moving the bulb back or forward just a tiny bit can make a huge difference in output, so I'll have to fit each one when they are ready to be installed to get the best light.
Because of the nature of projectors, if you retro them in the reflector is basically going to just be aesthetic. The beam is projected beyond the reflector, basically. They shouldn't make much difference one way or the other.
I'll be posting pics as I go. Tweaked my back today, so I can barely move. I may not get much done this weekend.
DenaliAK
DenaliAK
Colder than you
Alaska
Ok, couple more R&D pics. I've now fitted the projectors into some shrouds. I put a black gasket around the shroud to fill the space, but there is still a little gap. Not much, though, and it may be needed for beam adjustment anyway. I think it looks pretty good. I still need to trim the shroud...I'm basically going to cut almost all of the shroud off leaving only the top part that is exposed to lens (and the only part seen aesthetically). It's just a tad too big to fit naturally in the fog light. The top portion of the shrouds will pretty much fill the fog light, so there will be very little gap and it should like a more natural fit than just the projector (although that would've been way easier...I'd be done by now...lol).
I'm hoping to get the shrouds cut and fitted tomorrow. I still need a precision cutting bit for my dremel. From there, I just need to epoxy the gasket in place and screw things together. Once everything is cut it should just go together easily with the two mounting screws. I never seem to have as much time as I want to just sit and work on this, though, so it could take me several days to finish this up.
Here's pics of the projectors in the shrouds:
DenaliAK
DenaliAK
Colder than you
Alaska
Grrrr again.
This "little" project has taken on a life of its own. I trimmed down one of the shrouds today and it still wouldn't fit. They are just a tiny bit too big to get in and it's annoying. If I cut any more then there isn't going to be anything left of them. I may as well just screw the projectors into the housing and call it good. I'm spending way too much little unexpected money on this trying to make it pretty. I can make it functional with no problems, but trying to make it aesthetic is a PITA.
Thinking I may go to Home Depot and just wander around and see if I can find some stuff to make it look finished without creating too much more work for myself.
soulsea
Bar
I've heard of folks wondering home depot plumbing depts. looking for shroud material .. I've never asked what it is they are looking for though so I'm no help at all. :)
ezdaar
Chat Troll
Redneck central, Aka Houston
Bud you are way over engineering this..
Think K.I.S.S = Keep, It , Simple, Stupid,....
rubber door trim...
Run something like this around the back side of the Large housing to seal the P1 inside.
Theres all kinds from round to blade edge, from 1/4 to 1" thick..
Rubber door trim Noone will ever see it and all you need it for is to keep the inside of the outter glass lense clean on the inside.
Its never going to melt.....
I am real curious to know what those fog shells would look like with some chrome paint on the inside walls and maybe even paint the outside of the P1's chrome..
would probly enhance the total lumen output greatly .
gknowels
