Foglight Housing
NoPh33rRaCiNg
Kent, WA
Whats the easiest to remove these and install new ones. I just took a quick glance under the truck looks like there is 2 bolts that screw downward into the bracket from the top. Looks like a pain to get to. I bought some new smoked ones off ebay im going to replace them with this weekend. Any tips/tricks?
vatahoelt
NoVa
you'll have to just get under there and remove the 2 bolts. no other real easy way to do it.
jESse
i like cheese
michigan
they're easy to remove and replace. i've busted off a few sets of fogs playing off road and such. they're easy to change out. just gotta crawl under there and do it :)
puckhead
CO
Pretty easy to get too, just leave room to crawl under the front of your truck. even better if you have a ramp to drive up on
NOPROBROBB
UTAH
souldnt take you long at all. It does require you to crawl under your truck and get on your back but shouldnt take you more than 15 to 30 minutes to get them swapped out, they re one of the easier installs in my opinion.
Only tip is make a mental note or a mark on a wall where they currently shine as to how high/low to adjust the new fog lights, i had to adjust mine quite a bit that i bought off ebay
swt_wxw
