Fosscore's 2006 Tahoe Build Thread
Fosscore
Fosscore
Yessir. I feel for you guys in the winter. Some mornings I get up and wash them at 0600 just so they are ready to go for school drop offs and the rest of the day. Watching the weather of course and not picking the rainy day. lol
kwOH
Banned
We are literally suffering here lol.
Sent from iPhone 7 plus using Tapatalk Pro
Fosscore
Fosscore
Stopped by the painters yesterday to see the HD hood. Worse or better, depending on how you look at it by finding the issues (good) or having to paint it for the 3rd time (bad and a waste of paint $$). He took a whole bunch of photos, but these 2 are what I have for now. We had issues/reactions on the exterior section visible on the surface of the hood after both times it was painted. The reaction happened pretty much immediately and it looked like someone has sprinkled sand/non-skid over the surface of the hood. It was very shiny, but just looked like crap.
The lead painter decided this time to do every prep step himself to ensure that this 3rd time is actually the charm. He started with 80 grit on the DA and was not making headway. He ended up using 30 grit to finally reach bare metal and get thru all the under layers of crap that were not taken off the previous time.
The prep guys had not done a good enough job during prep and left some contamination/rust in the under layers as they evidently had not taken it all off, thus allowing it to react/breathe once the top coat was laid down and the scorching sun hit it. Pinholes and any body work were visible from the surface, but too hard to take a photo of. It went all the way thru to the metal. grrrr...Always in the prep that makes the real difference.
There is a primer coat on it now and they will be filling,fairing and blocking it the end of this week and shooting another primer coat as he works his way up to the final coats. Hope to have more pictures of the process to post up soon.
jerryjoe28
That Guy
cabot AR
lol, im far enough south that I don't get much snow but with all the rain and the cool temps I cant keep the damn thing clean! :flame:
hope your hood works out better this time
Fosscore
Fosscore
Yeah no snow down here, but pop up rain showers even though this is the "dry season".
The hood will come out better this time I am confident. We've worked together on many projects over the years, boats and vehicles.
Sometimes a certain part needs a reshoot even a third time. Not bothered and they will make it right. Good work if relationship over the years.
BADRIDES
Do you have anything on the backside of the hood to protect it from engine heat?
Fosscore
Fosscore
Yessir. I have the OEM heat pad in place under there and have since it was first painted and it is still in perfect condition.
There was a only a bit of corrosion near where the light was mounted on the drivers side of the hood.
BADRIDES
Do you have the OEM pad from your regular hood or an OEM pad for an HD hood? I heard a regular hood pad doesnt fit well on an HD hood.
Fosscore
Fosscore
It is the OEM HD hood heat pad that came with the hood. They do not make it anymore and correct the regular hood and HD heat pads are slightly different.
My original hood is buried in the back of a shed, otherwise I would have a look to compare.
Al_C
