frame and rearend reinforcement
99thomas
rochester,mn
already decided on motor and tranny conversion for my 98-99 tahoe. problem is depending the motor is going to be a bb around 700 hp tq not sure yet. being in an area of salt use im not a fan of boxing the frame and for that reason would bracing be enough? it will never see a drag strip but maybe some playing around. already has a bds lift and i think i prematurely bought a 9.5 14 bolt before deciding on replacing the motor. i have to rebuild it anyways but after searching there isnt very much available to strengthen it so would ladder bars be enough or should just find a 10.5 and go that route
SunlitComet
OBS Jedi-Do Good
unknown at this time.
look at the bottom of your truck if 4x4. decent bracing there already and would give you ideas on what you should apply. i would say if you can increase the drivetrain and frame bracing sizing by 50% or more you should be good for your selected applications and use.
retorq
Kingman AZ
I'm planning on keeping my 10 bolt, welding the axle tubes to the housing, reinforce the spring perch, using studs inside the carrier, using a reinforced cover with studs and tying the cap support studs to tubes that extend out to the bearing area. A ladder bar isn't really going to strengthen the rear end housing itself ...
Bad pic but basically this: http://i.ebayimg.com/t/LPW-ULTIMATE-AXLE-TUBE-BRACE-KIT-REAR-END-DIFF-TRUSS-/00/s/Mjc0WDc3MA==/$(KGrHqZHJB!E+NzWfi6rBQ(NvttFTw~~60_3.JPG
The 14 bolt has a much better pinion bearing setup then the old school 10 and 12 bolts, I think it will handle 700 ft/lbs fine.
99thomas
rochester,mn
i was thinking ladder bars as support but thinking of building my own weld on truss since none are made for the sf as far as i can see. checked out the ebay one but not exactly what im looking for.
---------- Post added at 10:40 AM ---------- Previous post was at 10:38 AM ----------
anyone think it would be smart to just toss the lift blocks for new leafs with the added power?
Donnie Yukonie
Yates Caretaker
NO , not with those horsepower numbers ,the bigger the block the worse the walk, On stock trucks a 5 inch block is ehhh, with 700 hp ….. two words AXLE WRAP
_Dylan_
STAY FROSTY
Keep the blocks and build a really strong anti wrap bar.
I would just use the sf 14 bolt since you already have it.
Donnie Yukonie
Yates Caretaker
Well I wouldn't run a 700 hp on blocks ,
But what are Anti wrap bars?
you mean track bars?
ezdaar
Chat Troll
Redneck central, Aka Houston
Welding all frame cross bars to the frame sides will reinforce that frame a ton.
Adding gussets to the inside corners will help alot as well.
Just make sure your frame is square and level before welding.
Frame should be fully supported on jack stands, not sitting on its tires.
Alot of old school guys would fab and weld in a X bar from front to back.
Just go easy on how much weight you add, be smart about your bracing.
You add in another 400 #'s of material and that 700HP will feel like 500.
Dont forget about gusseting your leaf spring perches, aswell as the fram infront of and under the engine itself.
Your stock motor mounts are a NO GO. decide on aluminum inserts or poly graphite bushings.
Like these. There are other types that bolt to the frame as well.
http://www.skspeed.com/ProductDetails.aspx?ProductID=CAL2380
etreanor
