Free Travel Mod How To Guide
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
I USE A 9 AND 12 INCH metal cutting dewalt blade. buy 5 or each
popo8
Bout to do the free travel mod finally. When loaded its comin down on the bump stops.
Also... i was wondering. Should the factory air leveling system be able to level out a full trailer or am i expecting 2 much from all that weight.
Sent from my SM-G900P using Tapatalk
TheAutumnWind
Iirc the factory system is good up to 1000 lbs additional weight. You could also add an air ride kit if you require more support for heavy loads. Its pretty cheap.
popo8
U mean like a load leveler kit?
The trailer was 7k fully loaded... so I guess thats why it couldnt lift it.
Dan Acosta
Yes I use a sawzall cut below frame and good to go. The bumpstops I ship with the kit fit thru the oem hole thats on the axle pad
Hello, what bumpstops do you supply? How do I get them? Is it only in kits? If so which others would you recommend. Thanks Dan
popo8
I would also like to know what all is included with this kit, @NORCAL SS
wendal
Dallas
Does anyone know of any shop in Dallas that has done / can do the free travel mod? I've researched it and it's not something I want to take on myself... Thanks in advance!
z33garage
