Front and rear washer fluid not spraying
general98
I know there has been a lot of discussion about this but where should I sart? Plenty of fluid in the reservoir but neither the front nor the rear wipers will spray the washer fluid.
Donnie Yukonie
Yates Caretaker
When you activate it do you hear the pump running? does the wipers start moving as they should?
---------- Post added at 10:53 PM ---------- Previous post was at 10:52 PM ----------
Also just curious , Is your truck a 98 a model if so I can move it to the appropriate section , I see you posted this in the 2000 and up, Just let me know and I will move it for you
G
general98
The wipers work fine. I don't hear the pump come on.
My truck is a 2000.
Donnie Yukonie
Yates Caretaker
Well the Front and rear sprayers rely on the same Pump, Have you checked any fuses that could be related? If not I would bet your Pump is probably bad
G
general98
Where would I find that fuse? If the fuse is ok, is the pump fairly easy to replace on my own?
Donnie Yukonie
Yates Caretaker
To be Completley Honest Im not Sure if there Is a said Fuse , On OBS there is not one . but For a NBS i was assuming there might be, However Again I replaced Mine a few years ago on my truck and it wasn't bad at all Took me maybe 30 minutes with goofing off and Not having a clue at what I was doing
WINGMAN0711
