Front axle seal?
ch4d
A Podunk town in Oregon
So i went into schawbs today to fix my flat and they looked around my front axle and on my driver side front axle the seal went to shit so how should i tackle this?
1999 tahoe
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Common issue. It's not really a problem unless it is dripping and leaving spots on your driveway.
Sent from my myTouch_4G_Slide using Tapatalk
It is not a common issue. Seals and gaskets just fail that is all there is to it.
---------- Post added at 01:37 AM ---------- Previous post was at 01:34 AM ----------
BTW you remove the half-shaft and pull the seal from the differential and install a new one with the proper seal driver.
purple 'hoe
Green Bay, Wisconsin
Common issue? Sure I price out that job almost daily at work.
But I'd rather tackle a leak when it's small. Once it starts throwing out your diff fluid like crazy, there's always the possibility the front diff was run low on fluid, and has torn up the ring/pinion or other internal parts. So yeah, I'd fix it when it's just starting. No sense in running it till it's pissing fluid out.
C
ch4d
What does it usually run if i want to take it to a mechanic?
purple 'hoe
1.7 hour job if I recall correctly. Seal itself is like something around 20 or 30 dollars. Add a little bit in to top off fluid if it's low. I can look up exact labor time tomorrow at some point from either Service Information or All Data.
C
ch4d
Thanks a lot.
nicholsphillip41
