Front bench seat
massivespl
I'm not mean, I'm honest.
Michigan
my Tahoe is gunna get a bpillar wall with my 4 18s within the next year... I'd like a bench seat so I can fit 3 people "me,wife,son". Will a Silverado bench bolt directly into a Tahoe? Or am I gunna have to have a buddy weld up a bracket?
YukonXL04
The Riverboat
Arlington, TX
Yes any gm full size front seat of the same model will bolt right in. Best way would be swap your center console for a flip up jump seat, so when you don't have 3 people you still have a arm rest/storage. I just swapped my jump seat out and put in a factory console
abishoff
Did you previously have a bose system with the jump seat? I am converting from from console to center jump seat and i dont know where to put the bose amp or sub-woofer. I dont mind deleting the sub.
YukonXL04
The Riverboat
Arlington, TX
No I didn't have any bose. Also running all aftermarket audio setup. You should be able to relocate the factory amp to above the glove box... you might have to extend the wires though... as for the sub you could swap out to the sub/box setup in the 99-02 or just move the stock sub box to under the rear bench and extend the speaker wires
abishoff
Unfortunately, I use my glove box so there's no room for an amp. I think I'm just going to let it sit on top of the carpet where its original location is. I think I'm just going to go without a sub. I too am going to switch to an after market amp and sub at some point so for now I just need the factory Bose amp to power the speakers
YukonXL04
The Riverboat
Arlington, TX
There is room behind/above the glove box. I didn't mean inside it. In some years I believe the factory amp was there to begin with.
Also you will have to change out the passenger lower dash/glove box panel for one without a console as well. It runs the full length back to the drivers panel. The console one stops at the side of the console so you would have a big hole there if you don't swap it
lgksser777
