Front brake upgrade
bowtiefreak
No Quarter
Near Philly
Here I go again. I have tried many, many set ups....BUT I may have a winner. Just installed Hawk LTS pads (used them before and they seem to be the best I have used) and EBC slotted rotors.
Just took it out to bed the brakes in. 6-10 stops from 30, normal braking. Then 3 from 40 hard braking. It seemed ok, better than it was.
Pulled the ABS fuse 1/4 mile from the house, got up to 45, stood on it and locked them up. So far I am happy. Going to drive it again after the brakes cool and see how it goes.
A few things I've tried in the past:
1) hawk LTS / power slots. Worked good
2) EBC green stuff / R1 rotors. sucked. Threw the EBC pads in the trash and put hawks back on
3) Crap from Pep boys, ceramics with turned R1 rotors. Left a lot to be desired.
4) GM factory parts. It was OK
5) Hawk pads / EBC slotted. Pleased so far.
Note: this is on the suburban, not the tahoe. It gets attention later.
retorq
Kingman AZ
Locking up the brakes with new pads is the best way to break them in I heard.
bowtiefreak
bowtiefreak
No Quarter
Near Philly
I am so happy so far. Going to drive it around tonight to verify. But it felt good.
95escahoe
Sub for future updates, sounds like a great combo tho
Sent from my HTC One X using Tapatalk
SunlitComet
OBS Jedi-Do Good
unknown at this time.
the hawk sd pads are better. and if any of you have to do brake-ins of the pads do not let it come to a complete stop, hold the brakes down and wait a moment when they are very hot. you will end up with a hotspot on your rotors which will just cause issues down the line. if you have to stop see if you can't roll slowly a bit and when stopped put it in park and make sure service and parking brakes are released.
bowtiefreak
bowtiefreak
No Quarter
Near Philly
Hawks website steered me away from the SD. Said not recommended for 1/2 ton.
Was pretty rainy here last night and today. I'll drive it tomorrow
SunlitComet
OBS Jedi-Do Good
brake like i do and you will need sd and 4 years with the same pads and still working great. so great that I have micro-cracked both rotors.
bowtiefreak
bowtiefreak
No Quarter
Near Philly
Ok, test drove it last night. Very happy with this set up. I always had good pedal pressure. That with properly adjusted rears and upgraded front seems to be good.
Jybfan04
