front brakes question
crayfysh
Indianapolis
ok, so im due for a front brake job. so do i go with standard pads and rotors or do i go drill slot rotors and ceramic pads??? and hydro boost is not in the financial aspect right now.
Lowufo
Slotted rotors and ceramic pads for sure. If calipers have not been done recently do the whole thing while you are at it or murphies law you will be swapping out calipers a month down the road. Do a brake fluid flush while you are at it as well as inspect the rears. This way you can rotate the tires while they are all off the truck.
crayfysh
crayfysh
Indianapolis
ok now i see they make synthetic brake fluid, should i use that or just go with the standard stuff? dot3 of course cause anything you mix with it becomes it anyway.
Donnie Yukonie
Yates Caretaker
I went with R1 concepts D/S rotors and ceramic pads , couldn't be happier. great company and great prices If you want I can hook you up with a vendor and a discount .
SunlitComet
OBS Jedi-Do Good
unknown at this time.
okay in case you all have not noticed all brake fluid is synthetic. it is all man made and not derived from some petroleum source like oil or fuel is. the synthetic in the description is just a marketing ploy. use dot 3 or compatible only.
kendrick newborn
