Front Camera Question 2004 Yukon
Run4st
Hello All. I did do a search but no clear answer found on forum or web...I am installing a Dble Din Boss radio on my 2004 Yukon. I am using the Crux adaptor so steering wheel controls/Bose sys will work. On the radio there are connectors to add rear camera which seems like an easy install....Head unit has connectors for front camera also. I have an extra camera so thought I would install. The trigger wire for the front is what I am unsure of. I know the trigger wire for the back needs power sig from backup light to make it work (turns on as soon as you put in reverse). There is a trigger wire also for the front camera. Any thoughts on what to connect the front cam trigger wire to?
Thanks.
R
Trey Hardy
Eastern North Carolina
Thanks.
R
On my kenwood radio there’s a camera button where you can switch from the front or rear camera a lot of times I’ll keep the rear camera on when I’m towing sketchy stuff to make sure I don’t loose anything off the trailer lol
ivin74
05 NBS Nali
Htown, Texas
Thanks.
R
I didn't need a trigger wire when I did the front camera on my 05 YD. Not sure why you would need one
GMT430guy
