However, I only have one shim on there right now. Where do you order more from?
I would suspect that you can get aftermarket shim kits for the front, just as the rear.I would go to the dealer again. You can get them in varying thicknesses under the same part number. Ordering from Amazon you do not know what thickness will come, same for ebay.
I knew you were talking about the front but I had a brain fart when thinking about the shims; they're installed totally different so the super shims don't really get you anything on the front. That being said, Ibet the Yukon/Motiv shim kits are just as good as the dealer offerings.Thanks for the shim tip CountryBoy19I'll have to take that into account when I rebuild the rear (possibly helps on front too). This question is on the front 8.25 IFS diff...
For this measurement I locked truck into 4wd so the axles would keep diff from spinning while I tested it.
So I measured backlash as observed from the yoke (although spec is 0.060 - 0.010" at ring gear). I got 0.085" on the pinion yoke. Not sure if that is equivalent to measuring at ring gear? I don't think it is despite what people are saying in forums, the yoke is a lever connected to the gear. Although possibly yoke is at same height as ring gear or very close?
Then I applied a little extra force and got extra slop out of the diff. This has me a bit worried... I'm not sure what this slop is. Any ideas?
I may need to remove the inspection cover to take a closer look.
The Truetrac is a maintenance free limited slip. But unlike a normal clutch type limited slip that transfers less torque the more it slips (due to heat build-up in the clutches etc), the Truetrac's unique, patented mechanism bites harder (locking the 2 wheels together) with more torque and slip. I was skeptical of the mechanism so I looked up a few youtube videos. You can jack 1 wheel up off the ground, block the fronts so the truck won't move, and the single drive-wheel touching the ground will drive pretty hard at nearly the same speed of the free-spinning wheel. It will squeal the tire on the pavement. Everything I've seen and read on it has reinforced that it's a truly amazing differential. One that performs as good as the factory G80 without the delicate engagement mechanism of the G80. The difference between a clutch-type limited slip and the Truetrac is that any time the wheels are spinning at a different speed there is clutch-slip & resistance with the clutch-type. This means they have to balance the resistance of the clutches with driveability. The Truetrac doesn't really start biting until there is an actual torque difference, so during street driving, the speed difference around a turn doesn't cause much bite because there isn't really a difference in torque, even though there is a speed difference. It's not until 1 wheel begins losing traction, causing a torque difference that the helical gears start to jam up in the housing and send torque back to that wheel.Is TrueTrac the posi locker? G80 setup?
I hit my head after I posted the video... I think that big slop is coming from my CV Axles. The upper joints are shot, they have LOTS Of play in them. Guy I bought truck from had put leveling keys in, but not thought about anything else. It ruined a bunch of stuff up front. I lowered the truck back down... and had always suspected the CV(s) but now I know they are loose as I have replaced all the other broken parts (shocks, axle bearings and seals, and sway bar links).
Everybody seems to be measuring the front IFS at the yoke. Makes no since to me other than you could tell if there is a little or lot of backlash. The yoke creates a leaver arm / multiplies the measurement so no idea telling how much more you're reading than at the actual gear. Long story short, I think my internals are good up front.
I blew up my rear end though so your comments will come in useMy G80 is sitting on the ground in garage, I threw in a whole new (junkyard new that is) open diff rear end in the back. I want to put the G80 back in there, but a not sure how much metal filings are in it from the exploded rear end :|
